My account locked
Hemanshu
My account lock and I can’t access due to number change and not received full access
@Hemanshu  You. Can also try tapping resend code a few times or put in a wrong code few times you should get option to send code to email instead . If still no luck get support to help you regain access
send a  private message   To CS_Agents click
Hemanshu
No it’s not giving me option
Click/tap on the button that says that you didn't get the code. There should be an option to have it sent by e-mail.
