My 90 day plan expired
jkeizer13
90 day plan expired and it did not auto renew. I am trying to change my plan now to a 30 day plan but it will not allow me to do so. It also gives me no reason why I cannot.
jkeizer13
With not having a call centre, I feel the option to change plan after a service interruption should be available without a moderator as well. It just makes too much sense considering we do not get the service unless the service is paid for.
Thanks for the tip!
@jkeizer13, for your future reference, and others who may not know of this quirk, if you do decide to change plans in the future, set the plan up a couple days before your renewal date, and select the option to change on renewal.
This way, the system gets a heads up that. You want to finish the period, and at the same time, change the configuration of the plan.
I do not understand why it’s not possible to renew service intrtuptions with a new plan configuration, without Moderator help.  Seems like an idea that should already be there.
jkeizer13
Thank you. I am awaiting a response from them as of last night. I was really hoping I didn't have to continue the 90 day plan and then change it afterwards
@jkeizer13, once your account is in suspension,  you cannot change it yourself.   You need to get a moderator to do it.   You just need to send a private message to the moderator team and ask.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
jp2
You cannot change plan while account is in suspension. Only mods can do that for you.
