08-20-2020 04:03 PM - edited 01-05-2022 12:37 PM
Hi all,
I have been logging into the community with web browser Mozilla Firefox.
It always freezes up my entire window and to shut it down is very difficult.
I was wondering if anyone else has this problem with Mozilla Firefox?
I am using Microsoft Edge for this message. Using Edge I have no problems.
Thanks in advance for any Mozilla advice or I may just have to switch to Edge for this community.
Andy
08-23-2020 11:02 AM
I have issues with mozilla based browsers. On the phone, I use firefox and on the PC I use seamonkey.
08-23-2020 02:58 AM
@gpixel wrote:@throwinbombs try restarting your computer. do you have a lot of extensions installed on Firefox? try and update Firefox and all your extensions.
are you able to provide any information on the computer you're using? processor, ram, windows version etc
I've had no such issues with FireFox, and I use it all the time, but then I also have no extensions installed either, so it wouldn't surprise me if an extension was causing the issue.
08-23-2020 02:09 AM
I find Mozilla crashes once a week I just shut everything down do a hard reset and start all over again.
08-20-2020 07:20 PM - edited 08-20-2020 07:22 PM
@gpixelthanks
Just tested in private mode, the issue is still exists
08-20-2020 07:06 PM - edited 08-20-2020 07:21 PM
@Arpad beast! do you overclock your 9700k and 1080?
what happens when you use private mode for firefox?
08-20-2020 07:04 PM
same issue here, im using i7-9700K, GTX1080, 64GB RAM.
looks like firefox has this kind of issues on multi website sometimes, not just on PM. maybe use chrome for better experience.
08-20-2020 04:14 PM - edited 08-20-2020 04:16 PM
08-20-2020 04:14 PM
@throwinbombs I also use FF browser all the time and don't experience any particular issue. Do you have the most up to date version of Firefox. Maybe you need to update?
08-20-2020 04:06 PM
@throwinbombs wrote:Hi all,
Andy
Andy; I've used Firefox exclusively and had no problem...so far. The website can be slow-ish...but never the kind of symptom you've described.
