Moving to $40 15plan from old plan, do I get to keep my month rewards?
fathom
Planning on moving my old plan over, does all the referral rewards get transferred over also?
JL9
Yes you do and for the love of God never leave them lol, the only way you can do so is if you accept the change online and it takes 2 or 3 steps to do, so hard to do inadvertently. Just be careful bc your rewards are like precious diamonds/gold compared to the new rewards plan.
walker1
@fathom
Yes you get to keep all of them!
Because their stuck to your account not the plan your on. Good luck and enjoy.
That's what happened to me!
dabr
@fathom   Yes, the rewards stay with your account and changing plans doesn't affect them.  Reminded to select the correct $40 plan as there are two, use the arrow to the right of plans page and also Change at Next Renewal as PM doesn't prorate/refund for unused days left in the current cycle, plus rewards also won't get applied for immediate plan change.
