More rings
LinMac01
How do I reset the number of rings before voicemail kicks in
1 REPLY 1
@LinMac01
The number of rings is determined by the 'number of seconds to wait' before forwarding the call to your voicemail. Get your PM voicemail number from your Phone Dialer settings.
Dial this sequence: *61 *16475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
  • one ring, enter 5.
  • two rings, enter 10.
  • three rings, enter 15.
  • four rings, enter 20.
  • five rings, enter 25.
  • six rings, enter 30 (This is the maximum number of rings/seconds).
SAMPLE: *61*16475804001*11*20# [SEND or CALL] - sets your phone to ring four times (20 seconds) before going to your voicemail. Best to check mailbox.
( also technically, dialing *61*16475804001*11*20# can be shortened to *61*16475804001**20# since voice service is assumed)
