08-21-2026
11:40 AM
08-23-2026
10:58 AM
Dunkman
08-21-2026 11:13 PM - edited 08-21-2026 11:14 PM
hi @ANSON3 you cannot call voicemail? you need help hoe to program it?
or if you just want the numbers, here you are
08-21-2026 10:12 PM
or long press 1 on the dial pad.
08-21-2026 05:40 PM
Just dial your number.
08-21-2026 05:11 PM
HOW DO I GET MY PUBLIC MOBILE VOICE MAIL NUMBER
08-21-2026 11:44 AM
someone else had the same question...read the solution...
https://productioncommunity.publicmobile.ca/t5/Get-Support/More-rings/m-p/1265891
08-21-2026 11:44 AM
hi @ANSON3
Dial: *61*16475804001*11 *[then enter nulmber of seconds to wait] # [SEND or CALL].
For the number of seconds to wait from above - choose from the following options:
For one ring, enter 5.
For two rings, enter 10.
For three rings, enter 15.
For four rings, enter 20.
For five rings, enter 25.
For six rings, enter 30 (This is the maximum number of rings).
