05-26-2022 08:36 AM
Hello I ran outta data and would like to upgrade to receive more. Can you help me
05-26-2022 11:15 AM
How much longer until your next renewal date? This will help determine your best course of action.
05-26-2022 09:53 AM
1. You buy data add-on to handle your data need until next renewal date.
2. You can upgrade your plan if you know you will be using additional data in the future regularly. In this case I suggest to schedule plan change instead of change plan Now so you do not pay extra for 2 plans.
05-26-2022 09:22 AM
To add to the above information. PM does not pro-rate plans. If you change plans immediately, you will lose whatever is remaining in the original plan.
The quickest options include purchasing an extra data add on, or changing plans immediately.
05-26-2022 08:42 AM - edited 05-26-2022 08:44 AM
@Trey11 That are three things you can do
You can buy Data Add-on if you think it would be enough for you to use till the next renewal:
1GB Add-on - $15.00 (10 Reward points)
200MB Add-on - $5.00 (5 Reward points)
Just remember buying add-on is a 2 steps process, you load fund first. After successfully loaded, you go back to the Purchase add-on page and then buy the addon with the money you just loaded
You can also make a plan change to a different plan. You have to pick a plan DIFFERENT from your current one. If you make a plan change, make sure you understand the difference between Change Now or Change on the next renewal date In your case, you likely want to click Change Now to make the new plan starts now so you can enjoy the new data
You can also renewal your current plan early. But you will need PM Support to help with this You can first load your plan amount into your account, then open ticket with PM Support and have them to manually process the early renewal for you
To open ticket with PM Support for helping to renew early:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
