07-22-2022 06:16 AM
My plan renewed yesterday (first day of cycle is the 21st), but noticed this morning the 22nd that my monthly data in self serve still shows as being 100% used. I have some data bonuses accumulated so I was using them up until the plan renewed... just wondering now if if those are potentially still being deducted from vs what should be the new monthly 1gb data allotment in the plan? Calls and sms are working so plan did renew (and got the automatic "let's keep the conversation going", etc texts yesterday). Not sure if this is another bug with the new self serve or if this is happening to anyone else? Thanks
My Account
07-22-2022 09:31 AM
It seems to be reset now. Not sure if it was a caching issue, also heard back from PM Support and they confirmed all was fine on their end. Thanks again
07-22-2022 07:41 AM
I'll try that too, thanks
07-22-2022 07:37 AM
@jor123 try to access on some other browser (Edge/Chrome/Firefox) or try in Incognito mode as well. There were others with similar data reset problem but turns out it was just browser cache issue and they got the real number after they tried above
07-22-2022 07:05 AM
@jor123 wrote:Thanks, I just did that... Is this an issue seen before?
Unfortunately, this has happened before to some customers.
07-22-2022 07:04 AM
@computergeek541 wrote:
@jor123 wrote:My plan renewed yesterday (first day of cycle is the 21st), but noticed this morning the 22nd that my monthly data in self serve still shows as being 100% used. I have some data bonuses accumulated so I was using them up until the plan renewed... just wondering now if if those are potentially still being deducted from vs what should be the new monthly 1gb data allotment in the plan? Calls and sms are working so plan did renew (and got the automatic "let's keep the conversation going", etc texts yesterday). Not sure if this is another bug with the new self serve or if this is happening to anyone else? Thanks
Only a customer support agent can reset your plan's data usage to zero. Please open a tcket by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
07-22-2022 07:00 AM
