03-15-2022
08:01 PM
03-15-2022
10:25 PM
computergeek541
New sim card, calls and text is working, internet/mobile data is not. I have a Ulefone Armor 6, not in the specific list. I tried to reset network settings, restart phone, etc nothing works. I can't change APN settings manually with my phone, what to do? If i put the sim in another phone the Internet works
03-15-2022 08:25 PM
Hi @Laurentius , what @0077 suggested about factory reset is unnecessary. Likely you get all the data erased and still not get the correct APN
Using Freedom SIM is the easiest way if you have a friend that can lend you the SIM
also, check the thread from another owner of your phone
https://productioncommunity.publicmobile.ca/t5/Get-Support/Ulefone-Armor-6-APN-issue/m-p/377874
03-15-2022 08:18 PM - edited 03-15-2022 08:19 PM
@Laurentius I will assume the little + sign to manually add APN settings is greyed out?.
You'll need to find a Freedom Mobile sim card to solve your problem. If you're in a province that sells freedom then stop at a store and see if you can borrow a sim for a few mins or if you know a friend that has one borrow it for a few minutes to be able to change your APN settings. Oflr try ordering one off Amazon. Roam mobile sims apparently work as well and allow you to change APN settings.
You can use the search feat on these forums to search your phone. Alot of threads come up about this issue with APN settings for that particular phone and the resolution is a freedom sim card to be able to change APN settings.
Or private message support at link below. They may be able to text you an APN file that will upload to your phone.
03-15-2022 08:15 PM - edited 03-15-2022 08:25 PM
You do not need to factory reset your phone. What is the OS you are on? This particular issue if you have greyed out APN settings or no edit option is showing is solved by the following options:
Try the first option if you are unable to use this option choose one of the other two options to change your APN to public mobile's.
Edit: in bold.
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
