05-03-2023
01:33 AM
05-06-2023
10:28 AM
Dunkman
I have mobile data set to on but I cannot get a connection and I have plenty of data left. Is there another setting I need to set?
05-03-2023 03:36 AM
Android. No go
I turned off wifi and enabled mobile but still no connection
Nevermind, it took a 1/2 minute and stated working and I see IP/DNS addresses now
I also swapped my sim to another phone before and the mobile data worked right away.
Thanks!
05-03-2023 02:39 AM
@martik777 you are good you found the APN settings in the end
do you have an iPhone or Android? Was your phone used on PC Mobile before??
Try to click Reset All Networks and see if data starts working again. (Please note Reset all networks will delete your saved Wifi connections as well and you will just need to re-join them)
05-03-2023 02:28 AM
was set to Prefer LTE, changing to 3G doesn't help
05-03-2023 02:27 AM
APN is set to PC mobile sp.mb.com Why PC and not public?
05-03-2023 01:54 AM
@martik777 wrote:I have mobile data set to on but I cannot get a connection and I have plenty of data left. Is there another setting I need to set?
Check that the phone APN is set to sp.mb.com and that mobile data is enabled.
05-03-2023 01:51 AM
is data the only problem?? Voice ok?
First, try reseat your sim card. Power off first, take sim out for a minute before putting it back and power up the phone.
if that does not work, try changing the Preferred network type or network mode to 3G only and see if it helps
Also, can you confirm how much data left once again but use Incgonito mode to login My Account??
