06-01-2023
08:43 PM
01-12-2024
12:51 PM
computergeek541
Why is that I have to keep signing in to my mobile app. It's not a web site it's an app, I should be able to go directly to my account whe
06-01-2023 10:57 PM
06-01-2023 10:55 PM
@LitlLdy could be an iphone/ipad issue. My PM app on Android works well 🙂
let's hope the v2 will be better
06-01-2023 10:52 PM - edited 06-01-2023 10:54 PM
@softech wrote:@LitlLdy you are on iPhone?
try turn off clear cache when exit on Safari and test the app. The app actually calls the browser to connect to Telus login server, I think it might work
@softech , no, iPad. I don’t use my phone online. My iPad is much bigger to see & type on. So far with background app refresh enabled the app is still logged in!
Just read one of J_PM’s posts “Facts & Troubleshooting”
Is there a way to save my password for App? Why do I have to keep logging back into App?
We know there's is an issue causing customers to re-login a lot, we are working on it, but in the mean time we recommend using a service like this to make logging in easier.
06-01-2023 09:27 PM
06-01-2023 09:21 PM - edited 06-01-2023 09:22 PM
@softech wrote:@LitlLdy i know the topic is app.. lol
but i just have trick to browser..
app, try uninstall and reinstall. And I wonder some app security setting clearing the app cache
@softech , I don’t have background app refresh enabled for it so I will enable it & see if it makes a difference. It’s a new install. Maybe a new update in the future will fix it! As it is after I sign on it refreshes repeatedly before it will load anything. Huge lagging (not my internet). It’s new so it will have issues!
If I find a fix to keep it signed in I will report back @badboy1245
06-01-2023 09:13 PM
06-01-2023 09:10 PM - edited 06-01-2023 09:13 PM
@softech wrote:@LitlLdy on the app or browser?
9f browser, there is an option to "clear cache on exit" disable it
@softech , whoops sorry, thought we were talking about the mobile app! 🤣 I meant to type mobile app like Op did in post but I forgot! Sorry 🤣
Edit: Browser is used in private/incognito mode. Nothing to clear. So for that I understand it not saving it but the app should! Maybe only for certain devices. I don’t know!
06-01-2023 09:06 PM
06-01-2023 09:04 PM
@softech wrote:@badboy1245 it works for me
the 5 min trust 9n browser or app.?
@softech , selecting trusted device doesn’t work for me. When I open it again it gives error messages then asks me to sign in again then code sent to phone again. Maybe it’s my device!
06-01-2023 09:01 PM
06-01-2023 09:00 PM
The truest divice is only good for 5 minutes and then I have to keep signing in
06-01-2023 08:48 PM
The PM app doesn't support automatic login, it functions more like a banking app.
06-01-2023 08:47 PM
I do that and it keeps asking for a password
06-01-2023 08:46 PM
@badboy1245 It's an "app" but I don't see it as an app in the real sense. To me it's almost just a wrapper for their website. If an app you should be able to use biometrics if supported by your device in order to log in securely to the app. It'll be baby steps I think.
06-01-2023 08:45 PM - edited 06-01-2023 08:46 PM
Did you click on trusted device while login to your account?
You also need to click on trusted device again once you enter the 2FA code.
06-01-2023 08:44 PM
@badboy1245 Tab the box that says trusted device when you sign in next time should help
