03-01-2022
09:01 PM
03-01-2022
09:22 PM
computergeek541
I can call and send a txt so as receive a call, txt with my new phone.
But not able to connect the most important mobile network.
My phone is Sharp Aquos sense 4 lite which I bought it in Japan.
I wonder if my phone is compatible with the Public Mobile network or not.
03-02-2022 02:35 PM
Lol....sometimes we miss the most obvious of things. Happy to hear you are up and running.
03-02-2022 02:35 PM
It works now after I toggled Mobile Data off and on.
I am much appreciated for all of your helps.
Woooooo~~~~~~~~~
By the way I changed back the APN type to the original of “default,mms,supl,hipri,fota,cbs,xcap”
03-02-2022 01:48 PM
03-02-2022 01:37 PM
03-02-2022 01:36 PM
That only has to do with porting your phone number into pm. You can ignore that message.
03-02-2022 01:34 PM
@TSHIMIZU : That thing you found is all about porting your number. It would have no bearing on data.
To use the cellular data on the phone instead of wifi you need to turn cellular data on. Might be called Mobile data in your connection settings.
The permissions of the browser to use that connection would be in Apps and find the browser and set it. If that's the problem.
03-02-2022 01:25 PM
I can’t follow the meaning of turning on cell data.
Yes, I can browse with home wifi.
I may not have the permission for the browser to use cell data yet, see following article that I found.
“Your old SIM card must be inside your device and your account with your previous provider must still be active so you can receive and respond to the SMS and authorize the request. Please do not replace your old SIM card with your Public SIM until you have responded to this message.”
03-02-2022 01:11 PM
Can you add fota,hipri back into your APN type?
03-02-2022 09:49 AM
@TSHIMIZU : Dare I ask...you turned on cell data right? Have to ask. It's happened before where someone had forgotten to turn it on. You have the permission for the browser to use cell data right? Can you browse with wifi?
So another variation is (from above by darlicious):
MMS proxy - mmscproxy.mobility.ca
MMS port - 8799
But I think those are much more for MMS, not just browsing.
Also try:
MVNO value - 4D
03-02-2022 02:25 AM
Failed showing ‘No internet connection’
03-02-2022 01:25 AM
1. remove . after alias. aliasredirect is all one word (unless that's a typo) - but that would really only be for MMS.
2. MVNO type set to GID
3. MVNO value set to 4D4F
4. for fun set Bearer to LTE
5. keep the IPv4
6. you probably don't really need all of ,hipri,fota,cbs,xcap
We can try out a couple other variations after you try these.
03-02-2022 01:16 AM
I can’t make APN type to “blank”, changed APN protocol to “IPv4/IPv6”.
After I turned my WIFI and phone off, I tried to connect to PB mobile but failed showing “no internet”.
03-02-2022 12:11 AM
03-02-2022 12:05 AM
@TSHIMIZU try changing APN type to blank and APN protocol to IPv4/IPv6
03-01-2022 11:59 PM
My phone shows
APN: sp.mb.com
Proxy: Not set
Port: Not set
User Name: Not set
Password: Not set
Server: Not set
MMSC: http://alias redirect.net/proxy/mb/mmsc
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl,hipri,fota,cbs,xcap
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enable
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
03-01-2022 10:22 PM - edited 03-02-2022 12:37 AM
Pm has a few APN' that work. Posting yours would help us identify the issue but compare yours to this one.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
03-01-2022 10:19 PM - edited 03-01-2022 10:21 PM
@TSHIMIZU wrote:APN is " sp.mb.com "
@TSHIMIZU can you post the rest of the APN settings? maybe a screenshot, something like this:
Name: CA - Public Mobile Web
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMSC:
MMS Proxy:
MMS Port:
MMS Protocol: WAP 2.0
MCC:
MNC:
Authentication Type: PAP
APN Type: default, supl
and yes, the frequency list you post is pretty much what I found and confirmed that your phone's Mobile Data shoud work here.
03-01-2022 09:55 PM
According to Sharp Aquos, my phone works on
4G:B1/B2/B3/B5/B8/B12/B17/B18/B19/B39/B41
3G:B1/B2/B5/B6/B8/B19
PM&TELUS work on B2:1900/B4:1700/B5:1900/B7:2600/B12:700, it should work on B2,B5&B12.
03-01-2022 09:40 PM
Public Mobile uses the following frequency bands:
Can you find your model to check here:
https://www.kimovil.com/en/frequency-checker/CA
https://www.frequencycheck.com/
03-01-2022 09:39 PM
I cannot find any reliable source to confirm the frequency info. (the most reliable one, Sharp Japan show in frequency info at all!!) However, many sites all seem to say it does have the frequencies needed for PM.
and yes, as @Anonymous suggested , start with APN, does it have the proper APN setup?
side chat: i used to have a Sharp flip phone , pre-Android time.. Love it,
03-01-2022 09:35 PM
03-01-2022 09:06 PM
@TSHIMIZU : I'll tentatively say it might work here. It actually looks weak for talk but you say that's fine. Could you post screenshots of your APN settings. Maybe we'll see something in there to get your data going.
