10-28-2019 04:34 PM - edited 01-05-2022 07:46 AM
I am not able to download mms on my mobile
Is there any setting thats need to be changed??
Pls guide
10-28-2019 10:33 PM
@SheetalkAfter enabling mobile data can you send/receive mms? If not what model of phone do you have?
10-28-2019 10:28 PM - edited 10-28-2019 10:30 PM
@Sheetalk If you send MMS, does it work?
10-28-2019 05:27 PM
@Sheetalk wrote:I am not able to download mms on my mobile
Pls guide
@Sheetalk As others have mentioned data has to be turned on even though MMS will not use data and also make sure that mms is part of your APN type in your APN settings if you are using an Android device.
10-28-2019 04:38 PM
Pls guide
In order to get the picture MMS working, you need to enable mobile data and make sure that your mobile data is working on your phone.
Always restart your phone after enable mobile data to configure the APN setting automaticaly.
