05-21-2024
12:44 PM
05-21-2024
04:51 PM
computergeek541
I had a 37gb bonus data sitting on my account that never use cuz I had more GB than I use every monthand it said it was gonna expire in 100 days, so I switched to the cheapest subscription to use it, same now it's gone. Had see experienced something similar? I am on the brink of cancelling this stupid service
05-21-2024 01:24 PM
Well, that's great... They ha6ve me bonus that Id never use then... Thanks for the replies...
05-21-2024 01:07 PM
05-21-2024 01:04 PM
05-21-2024 12:46 PM
HI @Juan3434
this is expected. There is a term there with this rewards that you cannot downgrade the plan or you will loss it
but try to ask support agent, they might be able to offer you another set or data, just less , that is for your current plan amount
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
