2 hours ago
Hi there,
I am not receiving my anniversary points since switching to the new rewards plan.
Can you also tell me when my anniversary as well?
Thank you!
Alessandro
57m ago
@alosardo the Anniversary points is always 10 points on your anniversary regardless of the length you have been with PM
2 hours ago
Is 10 points for every year with Public? Or just 10 points regardless of length?
2 hours ago
Just so you know the point are not automatically applied to your bill like the old Loyalty was. Did you check in the app under rewards? If nothing there you will need to contact PM.
2 hours ago - last edited 2 hours ago
It is probably September 4 (2018) if you create your Community account the same time when you activated your SIM.
Click on your avatar top right>My Profile.
2 hours ago
You will get them at anniversary. They do not show up now nor are added every 30 days as before.
2 hours ago
Use the PM app to confirm the anniversary date first. It can be found on the top of Account page on the app, around your name there
if really missed the 10 points, PM will help. Just open ticket with them using the Orange Chatbot icon on lower right, start typing Submit ticket, choose Contact Us and then follow the screen to login and submit ticket
