10-05-2022 08:27 PM
10-08-2022 05:39 PM
10-08-2022 05:37 PM
The message said you have run out of minutes. I have unlimited talk and text
10-08-2022 05:36 PM
Are you serious. I pretty sure I know what plan I have.
10-08-2022 05:32 PM
@sundayreader you meant the calls got cut off? can you explain a bit more what you experienced??
10-08-2022 05:18 PM
I have unlimited
10-05-2022 08:36 PM
@sundayreader What plan are you on? If on the $15 plan with 100 outgoing minutes, then perhaps you've used them up and now need to purchase add-on minutes for $5/500 mins to use until your renewal resets everything. Remaining minutes from the add-on will stay on the account until depleted as it doesn't expire.
All minutes are rounded up and retrieving voicemail will also use available minutes, so your minutes can go quickly depending upon usage.
