11-29-2024 11:56 PM
I am looking at changing my subscription to the new Canada-US-Mexico plan. When i look at the coverage map it only shows 4G and 5G in Canada, 4G in US, but nothing in Mexico. Is there a coverage map for Mexico?
11-30-2024 12:45 AM
you have to select Mexico or United States to see the Telus coverage using that map.
11-30-2024 12:27 AM
@mpetro1 - If you've been with TELUS or Koodo previously and roamed in Mexico, they offer the same coverage as Public does. For sure AT&T Mexico and another one, cannot remember if it is Movistar or Telcel.
11-30-2024 12:26 AM
Yes that's the same telus coverage map i looked at.
11-30-2024 12:23 AM
I looked up coverage map for Telus in US and Mexico. Looks like much of US is 5G and some 4G. Mexico shows mostly 4G and a few cities have 5G. Do I assume Public coverage would be same as Telus?
11-30-2024 12:23 AM
Public mobile only just recently introduced Mexico roaming package. There is no coverage map yet. It is possible that PM may not have one. I checked the Telus website and it does not look like Telus has a coverage map for Mexico.
