Messaging, calling, data not sending or recieving
annapinkdragon
Hello,
Just this morning I noticed that I could not send text or receive texts to and from my friends. When I opened up the messaging app it says "currently unavailable to send your message..."
I have tried restarting my phone, reseating my sim card, putting my sim card into my son's phone to see if it works and logging into my account to make sure it's still there,  and nothing has worked.
I don't know what is going on other than narrowing it down to my sim. Please help.
Thanks
10 REPLIES 10
annapinkdragon
Nope, when I dialed 611 it says "not registered on network".
I am outdoors so I should still have full signal.
annapinkdragon
My account is still active and nothing on the page says it's on hold or seems on hold. My credit card is still fine haha. I'll try dialing 611, that is the public mobile service number right?
Seems to me the account is on hold. Are you able to login to your account? What recording do you get when you dial 611? Did you recently have a credit card problem?
annapinkdragon
No, I cannot call in and out except for 911, and I also cannot turn on mobile data. It says that mobile data is unavailable.
dust2dust
So, I'm confused. Can you call in and out? And can turn off wifi and turn on cell data and go to a web page?
I have a phone that is doing an odd thing with some texts. Says something about trouble. It mostly works. I haven't narrowed it down yet.
annapinkdragon
I think that's what my son did, he went into some setting to "reset the sim", which nothing changed.
Yes thank you, I will send a support ticket. This website is still a mess.
@annapinkdragon maybe outage in your area? did you try  the phone far away from your current location?
annapinkdragon
Yes my account with number and plan is still working. I could not turn on my data or call anyone.
@annapinkdragon you said voice and data not working too? can you login My Account? is it showing account active?
@annapinkdragon  So the account is active ? Try resetting network settings . If still no luck . Submit ticket with support
private message   To CS_Agents click
