Messages
IreneR
Hello, I'm new to public mobile. My Message are not working. How can I get them to work?
2 REPLIES 2
Meow
Do you mean texting does not work?
You will have to open a ticket as ALL new customers have issue with texting.
hi @IreneR
Yes, if only SMS an issue, it is a PM system problem with new activation.   Voice, data both work but just SMS is the problem.  And with the SMS problem, it will affect account verification.   PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
