06-28-2024
11:29 AM
06-28-2024
02:55 PM
computergeek541
I have a Xiaomi Redmi Note 10 Pro phone. It is no longer downloading or sending photos. How do i fix this?
I have already set my APN to the following, but it still doesn't work. My OS is up to date.
06-28-2024 09:45 PM
Thanks!
06-28-2024 11:41 AM
You could try setting your APN settings to following:
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
Some customers also tried all Capital letters for APN: SP.MB.COM
While others have needed to deleted the existing APN. Then make a new APN with the above settings.
Afterwards, you can try to reboot your phone. Network reset of phone (note: this will erase any saved Wifi passwords)
