Managing multiple numbers from one account
marciraxy
Hey guys is this possible can I have more than one number under one account for easy management if so how do I go about it?
Thanks
will13am
@marciraxy, a method many of us who manage multiple accounts is to use email aliases for each account.  Another insight is to be careful with using the same credit card for multiple accounts.  The system is known to not allow reusing the same credit card.  It can be done but multiple attempts may be required.  A practical consideration is that multiple payments with the same card at the same renewal time can trigger fraud alerts with the credit card company.
Rdasm
No there isnt. Its better this way because PM rewards you for referrals and I believe one number per account helps PM keep track of this for auditability and conflict purposes.  hope this helps.
ShawnC13
Thanks
No there isn't.  Each account must have it's own email address.
shartomjam
This is not possible.  Public Mobile supports only one number for each account.
