09-24-2024 11:15 AM
I manage my account and both of my kids' accounts using different email addresses. My questions are:
1. Has there been any move to consolidate accounts in the same household under one account?
2. If not, how can I make so I don't require text verification to log in to the accounts I use to manage their phones? (the "trust this device" option never works for me because of cookie settings) With texting a code, the only way I can manage their accounts is when they are present (i.e. not at school, out with friends, etc.) to give the code to me.
09-24-2024 11:36 AM
Thank you - great information to have!
09-24-2024 11:27 AM
HI @Nate12121
not the confirmation text, but the text saying something like you used up all data now, if you want to add, reply YES
it is sent from a 6 digits short code (not a regular phone number), but you can block that on the phone itself
09-24-2024 11:25 AM
So, there is a confirmation text that comes first that has to be clicked on the phone?
09-24-2024 11:24 AM
hi @Nate12121
that one is hard. LoL
all you can do is to block the shortcode PM uses to send the add-on purchase text
09-24-2024 11:23 AM
We don't know of Public Mobile will change this, probably not. I don't even know why they have this separate log in bit anyway. But...
If you have another phone number that is not associated with an Eversafe safe ID already, you can change the phone number on file to get the code. That is what I do.
I don't do this part myself, so i dont know if it works, but it is said if you remove the phone number completely, you can get the code sent to your email.
You would do these under the Profile tab, manage Eversafe.
09-24-2024 11:22 AM
Maybe you can also help me with this one: Is there a way to disable automatic add-ons so that if my kids run out of phone time, it won't automatically add more on?
09-24-2024 11:18 AM
hi @Nate12121
1. no , still one email for one account/phone number
2. if you manage multiple accounts, it is better to use Incognito mode to login. For the 2FA, you can receive them in email if you have access to the email. just click Resend code and then use Send email to get the code
