4 hours ago
I inadvertently bought a Canada Data Add-on instead of a US add-on . How do i get a refund!
3 hours ago
PM is prepaid carrier and usually do not provide refund. But we know in cases like this, they will help to switch. so, don't be shy, just submit ticket with pm agent
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 hours ago
@GeorgesChun, You will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
