6 hours ago
I signed up in June and paid $38.08 on June 08 and again June 14. How do I get the duplicate payment reversed?? Thanks
6 hours ago
@LewGatti wrote:I signed up in June and paid $38.08 on June 08 and again June 14. How do I get the duplicate payment reversed?? Thanks
First, check with your card issuer that one isn't only a pending charge. Some card issuers will show the same charge as both pending and posted for the same transaction. Once it has been confirmed that there are two different charges , open a ticket using the chatbot. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
6 hours ago
hi @LewGatti
why you paid twice? or you setup two accounts?
check with support. If a duplicated activation, they can help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
