11-28-2023 05:04 PM
I’m trying to transfer over my phone but apparently I made an error with the IEMI number how do I fix that
11-30-2023 10:46 PM
All fixed by Apple service provider in store.
11-28-2023 06:40 PM
I have an iPhone …did all the above and still no luck
11-28-2023 05:47 PM
@Deepi what phone do you have?
Data is usually APN problem
Reboot first and Try Reset all networks or Reset Network Settings
If iPhone, update the Carrier Profile
If Android, let us know and I will send you the correct APn settings
11-28-2023 05:44 PM
Thank you! Next issue which he couldn’t help me with is that my data is not working any ideas ?
11-28-2023 05:21 PM
Just on hold right now waiting
11-28-2023 05:19 PM
I would suggest not using IMEI when porting. Use the account number and it should work no problem.
11-28-2023 05:08 PM
@Deepi provide them account number instead of IMEI
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
