MMS
Demaks
Can't receive or sent MMS. Data is on, the APN is correct, did network reset, still not working. The provider is charging, but not providing service or help. Not happy!
14 REPLIES 14
Itis1
Thank you!  Thank you!  Thank you!!!!
Demaks
Your settings worked, thanks!
Hi @Demaks MMS issue have to be a problem with APN.
does sms work?
MMS ever work on this phone
yours is an android? clear message app cache or clear data
Demaks
Thanks for trying, but no.
@Demaks wrote:
This is different than what I have and what was told to put in. I have:
MMS proxy: 74.49.0.18
MMS port: 80
MVNO type: none
MVNO value: not set
@Demaks try mine.  It should work
DDM69
@Demaks so has this been resolved?
DDM69
@Demaks easy google search...
An active cellular data connection is required to use the MMS function. Open the phone's Settings and tap “Wireless and Network Settings.” Tap “Mobile Networks” to confirm it is enabled. If not, enable it and attempt to send a MMS message.
Demaks
I have Android.
Demaks
MMS port: 80
MVNO type: none
MVNO value: not set
Demaks
Don't know where to look for this setting.
@HALIMACS true .. miss that.
Then only check the APN
@Demaks one more thing, if you have an iPhone, make sure Carrier Profile is updated
Huh @softech ?
We don’t need a data allotment remaining for MMS, do we?
@Demaks you have data left?
compare your APN with here again
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
DDM69
@Demaks is MMS enabled on your device?
