07-14-2022 01:15 AM
I just bought a new phone - Samsung S22 ultra and I can't send or received MMS messages. The MMS messages say I have sent them but people are not receiving them. Regular SMS is working. Please help.
Erin
Service
07-14-2022 01:21 PM
So that's a non-standard, after-market app. Nobody asked 🙂 We'll have to remember to ask which app people are using. Great find. Thanks for sharing.
07-14-2022 01:18 PM
I'm using pulse SMS app- I go into settings>MMS configuration>APN configuration
Be sure override System APNs is OFF
07-14-2022 01:13 PM
Great news. For all future readers please do share what that setting was.
07-14-2022
01:11 PM
07-24-2022
06:46 PM
Luddite
apologies- just found a setting in my messaging app that was over riding APNs. I turned it off and now it works. Thanks for all the help!!!
(operator error uncovered by the operator 🤣 .... Luddite)
07-14-2022 12:50 PM
Just for certainty...you typed the whole thing in, right? Save, airplane mode, maybe even full restart. You have that APN as the selected active one too?
07-14-2022 12:50 PM - edited 07-14-2022 12:50 PM
HI @purpleman
you updated the line yet?
and why your APN type is using + but mine use comma
APN Type: default,supl,mms,agps,supl,fota,hipri
and your APN profile name now is Public Mobile 2. Did you select that one to use?
07-14-2022 12:46 PM
yes. still doesn't work
07-14-2022 12:45 PM
You could always ask for a CSA to send you a configuration file.
07-14-2022 12:35 PM
Did you save it and then go in and out of airplane mode to reset the connection?
07-14-2022 12:34 PM
Tried bothInternet+mms or Internet+mms+dun
Doesn't work and I can't manually change default settings. I can only add new network to make my own configuration. Still not working! Ahhh
07-14-2022 12:32 PM
Changed that and still doesn't work
07-14-2022 11:23 AM
This started happening to me same day as Roger's outage, I've tried all the fixes and thinking it might be a telus or public mobile issue as their new website doesnt work either most of the time. All plans come w unlimited text etc so wouldn't be that
07-14-2022 10:33 AM
aliasredirect.net
07-14-2022 06:37 AM - edited 07-14-2022 06:43 AM
Try Internet+mms or Internet+mms+dun
There is no option for you to enter your own values?
Edit:
Weird your screen is different than the guide. Try resetting to default and then edit if necessary.
07-14-2022 04:47 AM
Thanks so much for helping. I've tried this and it still doesn't work. The only setting I'm not able to get like you suggested is the APN type. Here are my choices
Here are my settings:
07-14-2022 04:22 AM
Check your network operator. Check your APN (see below). You may need to reset your network settings.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
07-14-2022 03:43 AM
I have done this with a couple friends. No one is getting my MMS messages. I have data turned on. I've rebooted my phone, reset the network a couple times. MMS is still not working. I can send photos via what's app. I have also tried a different texting app and it doesn't work either.
07-14-2022 03:35 AM
@purpleman wrote:I just bought a new phone - Samsung S22 ultra and I can't send or received MMS messages. The MMS messages say I have sent them but people are not receiving them. Regular SMS is working. Please help.
Erin
Send MMS to someone else or to your number. If they're received, the other people might have issue with their service.
07-14-2022 03:33 AM
@Timer wrote:turn on your mobile data to go through MMS
Purpleman says they were sent. How can they semd if data was off?
07-14-2022 02:54 AM
My data is on.
07-14-2022 01:36 AM
![](/skins/images/C206B3E09108DC4A8294A110EB9CCA46/responsive_peak/images/icon_anonymous_message.png)
