2 hours ago
- last edited
34m ago
computergeek541
My mms function is not working whether it's sending or downloading received media. I checked access point settings are also OK. Please help me
2 hours ago
In order MMS to work your DATA has to be on even though it will not be used.
2 hours ago - last edited 2 hours ago
@Asad3 @
there might be a bit more work than simply updating or changing network selection. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
2 hours ago
Have you tried rebooting the phone?
My co-worker had the same issue. I told him to go into his network settings and turn off automatic and pick Public Mobile and then reboot. It seem to work for him.
2 hours ago
is this something new or has it been happening as a result of you porting in to Public Mobile ?
