08-06-2024
10:10 AM
02-18-2025
05:13 PM
computergeek541
Hi, I recently switched to the OnePlus Nord N30 5g and MMS messaging is no longer working. I've made sure that the APN settings are correct. Is there anything else I need to do?
02-18-2025 04:51 PM
generally ia is not needed for APN type
but do you have any problem with your mobile data now?
02-18-2025 04:38 PM
Hey I was just checking my settings I'm wondering if you know about the APN type?
This is what it's currently set to:
default,mms,agps,supl,fota,hipri
This is what I found on lineA
APN type: default,ia,mms,supl,fota,hipri
09-11-2024 11:03 AM
Those setting fixed my OnePlus! Thank you😀
08-06-2024 11:00 AM
Thank you everyone. It's working now! I did everything; reset the network setting, used the detailed setting listed by softech and used all caps for SP.MB.COM. Not sure which one did it. Thanks again!!
08-06-2024 10:34 AM
With OnePlus, there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
08-06-2024 10:30 AM
@treehouse You verified that the APN settings are as in this link?
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
You can check for a specific phone with this link
08-06-2024 10:26 AM
Thank you. I just tried the all caps. It didn't help.
08-06-2024 10:14 AM
@treehouse You can also try reseting network settings also to see if that helps at all
08-06-2024 10:11 AM
@treehouse For OnePlus phones the first line in the APN settings needs to be in all caps, that is SP.MB.COM. Have you tried that?
