Lower dollar plan verification.
Grinch
I have been thinking of making some long term plans for more data and less data on the open market and of course more $ and less $. Or maybe break even.
On my logon, here are my lower $ upgrade options.
I see the 90 day options aren’t as attractive as before. Would you agree?
Correct me if I am wrong….there used to be a $23 plan that was only $19 and on the 90 day option and included  3gb a month. If you took the 90 day plan you were give 9gb of data right away and was up to the user to regulate it over the 90 days?? <= is this correct?
So is the $20 plan in the pic above (@$19/90 days) the same as the $23  (@$19/90 days)  that I just described above?
Thanks. 😀😀😀
1 REPLY 1
HI @Grinch
Yes, for 90 days plan, you get 9GB up front and you pay $19x3 up front as well
the 9GB can be used anytime within the 90 days,your choice
