Lost phone new sim and phone
12-02-2022 04:26 PM
Trying to edit SIM card in my profile to enter the new sim code to activate the new phone I got. The site won’t update the sim. Just zeros out the code when I hit the update button. Is there a problem with the site or am I doing something wrong
My Account
Service
12-02-2022 06:06 PM
Just to be certain, @Klf180 , if your just CHANGING your SIM card from a prior Public Mobile card to a new one (i.e. your prior one was lost or damaged or something), then just do that in self-serve after clearing cache and cookies and logging incognito tab. After doing so, log off self-serve and reboot your device after placing the new SIM card in it.
If you're a BRAND new customer, then tap Activate above and follow directions for activating a new service here. You'll need the SIM, e-mail address for username, a credit card, and your prior provider's account number if you're porting (moving) your number from there to here.
12-02-2022 06:06 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-02-2022 04:29 PM
@Klf180 Try logging in with incognito/private mode or use another browser as the site has terrible caching issues.
