Puk code
Shaddowclaw
I thought it was asking for my pin for the phone not the sim entered the wrong pin 3 or 4 times now have a puk lock how to get the puk code?
Yummy
Find your PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
Only Public Mobile's Customer Support Agents (CSA) can give you this type of code, which the device manufacturer cannot.
    Caution! If the PUK is entered incorrectly 10 times in a row, the SIM card becomes unusable.
tonisage
You need to send a private message to the customer agent.
@Shaddowclaw
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket:  https://urlshortner.tiia.ai/Oyn1L6
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
