08-16-2023 10:19 PM
I lost my phone and trying to log in to my account but it keeps asking me to enter the code sent to my phone. Obviously i cant. I did the email code but that was not enough
My Account
08-17-2023 12:12 AM
once you've initiated a question, you're given opportunity to indicate that someone has provided a solution to your question.
08-16-2023 11:11 PM
Its my first time being in the community, silly question why does it say solved on my post
08-16-2023
11:07 PM
10-12-2023
08:20 PM
I don't disagree with you. That's why I suggested you let CSA have a few of your thoughts on the subject of .. I mean Eversafe.
[updated by Softech: removed disrespectful comments]
08-16-2023 11:05 PM
@hairbag1 Thanks did it. I find a lot of people has the same problem as me.
08-16-2023 11:02 PM
08-16-2023 10:58 PM
@hairbag1 i cannot dial 611 from my home phone😟
thanks for your help
08-16-2023 10:41 PM - edited 08-16-2023 10:45 PM
they could respond this evening but likely in am fer shur. Let the CSA know what you think of the new Eversafe protocol too.
added...you can dial 611 to disable Autopay, if that helps. Make sure to re-enable it when ready for service again.
08-16-2023 10:39 PM
thank you, how long till the customer agent reply. I just need to report my phone as lost, eversince they changed the online sign in its been very difficult
08-16-2023 10:30 PM
you can send a message to CSA for their help...
If you're trying to pay and having trouble, you can get vouchers at Shell gas then dial 611 to add 'em to your account.
