06-10-2023 05:05 AM
I lost my SIM card.
I want to suspend my previous account and order a new SIM card with the same phone number. Can I do that?
06-10-2023 07:29 AM
Yes, sure why not. Also, If anyone want fantastic Mobile cases check out ACFootball Cases.
06-10-2023 07:00 AM
PM just changed to a new EverSafe login system and you need to complete the setup
If you have created an EverSafe, at the 2FA screen, click Resend code and then Click Send email to get the code via email
If you have not created an EverSaf id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support and have them to help in this situation:
06-10-2023 06:52 AM
But I cannot sign in my account because I cannot get 6 security digit to sign in account (I cannot get 6 digit to my phone because I don’t have SIM card)
06-10-2023 06:44 AM - edited 06-10-2023 07:04 AM
to Suspend your account for now, log in on a laptop > Profile..
get you a new sim, then log in on a laptop and Change Sim Number...you'll still have the same PM account and phone number.
Once you've successfully Changed Sim Card Number ...make sure you go back to Un-Suspend your account.
Now you're good to go.
