02-25-2019 05:23 AM - edited 01-05-2022 03:28 AM
02-25-2019 06:51 AM - edited 02-25-2019 06:55 AM
You have lost your phone @interceptor1001 but not your phone number and account. It’s very simple to go in your self serve account as mentioned above and do it yourself. If you still have problem don’t be shy and ask help from the moderator here...
Waiting time is few hours to 2 days..be patient if you need help..
02-25-2019 05:27 AM - edited 02-25-2019 05:28 AM
No problem, log into self serve https://selfserve.publicmobile.ca/ then go to plans & add-ons then change sim and insert the new number
