08-01-2019 01:13 PM - edited 01-05-2022 06:13 AM
My first major PM account issue!
I was on the $25 unlimited call/text/500 + 500 mb data plan and set up my account to switch to the $15 one. Anticipating this change, I decided to purchase the 500 min add on before the switchover.
Upon switchover, my $15 plan seems to be working fine but the add on was removed. I wrote the mods a few days ago but haven't heard back. Has anyone experienced this issue?
08-01-2019 01:16 PM
Looking at my transaction history more closely, seems the add-on got refunded, even though I didn't request that.
I'd like to add it back, but not if something is wrong with my account or the system.
08-01-2019 01:21 PM
@mh1983 wrote:Looking at my transaction history more closely, seems the add-on got refunded, even though I didn't request that.
@mh1983 The $5 is sitting in your account balance so just go ahead and purchase the add-on now and you should be good to go.
08-01-2019 01:22 PM
Yes, that's an option, but as I mentioned: "I'd like to add it back, but not if something is wrong with my account or the system. " I'd like to understand why the add-on got removed/refunded to begin with without my authorization.
08-01-2019 01:23 PM
the add on should be upload the fund first, then purchase, it is two steps. Make sure you purchased the add on successfully.
08-01-2019 01:24 PM
@missorange wrote:the add on should be upload the fund first, then purchase, it is two steps. Make sure you purchased the add on successfully.
I did, @missorange . It was previously in my account and I went through the 2 step process. Otherwise it wouldn't have appeared in my transaction history.
08-01-2019 01:26 PM
@mh1983 wrote:@mh1983 The $5 is sitting in your account balance so just go ahead and purchase the add-on now and you should be good to go.
That is a puzzler. When I first got it and then ran out of the 50 minutes, it went to the 200 add-on..not the 500. They fixed it by removing it and re-adding it making it look like a new purchase. But that's not what happened here.
hmm
08-01-2019 01:27 PM - edited 08-01-2019 01:29 PM
@mh1983 On the 6th you purchase the add-on on the 18th they refunded the add-on maybe because you are on the $25 unlimited canada wide plan and that add-on does not make sense to have. On the 29th you added $5 to your account but no purchase of an add-on was made. So when did you make the purchase of the add-on on the 6th or the 29th?
If it still doesn't make sense then contact the moderators but honestly I don't see an issue here.
08-01-2019 02:01 PM
You did buy and activate the 500 minutes, but for whatever reason, someone refunded to leave a $5 credit. On your renewal, the $5 was used, plus your rewards, and a small AutoPay top-up.
Your current balance should be $0 (ie the credit is not there). It was used to make your payment.
This *should not" have happened. You bought the addon, it should be refunded, whether they thought you need it or not.
@Alan_K, why would this happen?
08-01-2019 02:44 PM
@stonechucker wrote:You did buy and activate the 500 minutes, but for whatever reason, someone refunded to leave a $5 credit. On your renewal, the $5 was used, plus your rewards, and a small AutoPay top-up.
My guess is someone didn't want the add-on, perhaps really wanting a roaming add-on, and asked for a credit. Then a mod perhaps did that to the wrong account.
