06-01-2024 09:57 AM
06-01-2024 10:33 AM
@Wrascal wrote:Ok. I see that I have the one data loyalty add-on with 150 day expiry. All the others are one-time gifts such as a Christmas bonus. That's helpful. Mine would be a downgrade I guess from a $25 plan to the $19 offer, but it's a better plan than the one I have. My husband and son currently have the $15.00 plan, but theirs would be an upgrade to the $19.00 plan. They also have the timed data offer with 70 days remaining. So I imagine they would lost that data.
The $15 plans should not lose the 150 day loyalty data add on. Since it is an upgrade of the plan (ie. paying more)
A few customers have stated that when they switched from $25 to $19 plans, they actually kept the loyalty add on, YMMV though. According to FAQ, customers should lose that add on since downgrade.
06-01-2024 10:21 AM
clipped from the Help Files...
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
06-01-2024 10:17 AM
06-01-2024 10:00 AM
If you change plans, you will not loss any previous add ons (like XMAS give aways). However, if you got the loyalty bonus data add on (150 day expiry date), you may lose that add on if you downgrade your plan (as per FAQ).
