03-24-2023 09:19 PM
03-25-2023 12:09 AM
No. You can only use US Roaming add ons in the US but you can call Canada whilst in the US with any of the US Roaming add ons that include a talk feature. To call the US from Canada you need to have one of the following:
If you accidentally purchased a US Roaming add on you can contact customer support and explain your "honest mistake" and they will likely remove the add on and credit your account.
03-24-2023 09:41 PM
Also note, the long distance calling add on will stay until you have used it all up. No expiry.
03-24-2023 09:34 PM
Hi @5458
yes you just need to buy the US long distance add-on
Login to My Account, go to Plan and Addon page and the Buy Add-on there
03-24-2023 09:34 PM
@5458 , you need an in Canada long distance add-on to make calls outside the country. The US long distance add-on is $15 for 1000 minutes. These minutes do not expire.
03-24-2023 09:29 PM - edited 03-25-2023 01:25 AM
You don’t need roaming. Just long distance calling Add-on.
The cost is 1000 US calling for $15. Just login to your account and go to Plans & Add-on to make your purchase.
Did you get the More is Merrier promo around Christmas? You can use it if you replied to the text with YES2.
