Long distance calls billing based on dialing form?
doe
Taking into account https://productioncommunity.publicmobile.ca/t5/Discussions/If-I-text-or-call-a-local-number-while-th... is my call always considered long distance if I call +1-area code or only if that code in another province/country?
Thanks.
2 REPLIES 2
doe
@Luddite wrote:
Thanks.
Only to another province/country.
Clear, thank you
Luddite
Thanks.
Only to another province/country. Adding +1 to some provincial calls eliminates an annoying message that you may need long distance. With PM, any service that works is "free" because everything allowed is prepaid. All explained here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Province-wide-Canada-wide-and-Long-Dis...
