03-12-2019 07:51 AM - edited 01-05-2022 03:40 AM
03-12-2019 08:42 AM
Maybe a local prepaid SIM or global travel SIM for the local calls, and I'd recommend installing something like Fongo so you can call back to Canada for free over WiFi or data (data would incur a charge, obviously).
03-12-2019 08:18 AM
@Simmo69, you probably already have Facebook Messenger or another chat app installed. You can use this as your connection to home while away on WiFi or cellular data.
03-12-2019 08:04 AM
03-12-2019 07:55 AM
@Simmo69 wrote:Good morning...I am travelling to Panama in 4 weeks and will need to make calls locally down there. When should I purchase the add on to have that ability to make calls
Nothing for Panama with public mobile @Simmo69 . PM has US roaming add-on only. Look for local SIM card when you arrive.
Before you leave, you can setup WhatsApp with your family. Everyone in your family need to install WhatsApp on their cellphone. You can send messages over WiFi to family as soon as you get WiFI connection.
