12-03-2017 03:03 AM - edited 01-05-2022 03:40 AM
I haven't seen much discussion on here about LTE-A and after having finally purchased a phone that is capable I tested Public Mobile's network.
On my Galaxy S5 I used to get speeds between 30mbps - 85mbps on Public Mobile. The highest I achieved on the S5 with no network congestion was 126mbps.
I just ran my first test on a Galaxy S8, which is capable of LTE+, and I achieved 238mbps. I'm very confident that the results you can achieve on PM are almost identicle to what you would see on Telus/Bell.
Speedtest, no congestion
12-05-2017 03:04 AM
that's very fast, what area are you in? I never had such download speed.
12-04-2017 04:30 PM - edited 12-04-2017 04:31 PM
I have both an LTE plan, and a 3G (2.5mpbs LTE) plan which I am testing for 2 weeks now. Unless I am downloading a large app it pretty much feels like i'm using the same service. Youtube 1080p may take 5 seconds to load if fast forwarding.
12-03-2017 09:10 AM - edited 12-03-2017 09:10 AM
No practical difference between any Bell or Telus brands. See here for more info about how the network is designed:
https://productioncommunity.publicmobile.ca/t5/Discussions/LTE-network-fundamentals/td-p/130581
12-03-2017 07:25 AM
12-03-2017 06:47 AM
There was a discussion... A big one but just under a different title . Here enjoy reading if you want
12-03-2017 03:06 AM
Its the same network so you should get fadt speeds. only the ,3g plans are artificially throttled.
The LTE plans are full speed. 🙂
