11-04-2017 01:25 PM - edited 01-04-2022 02:52 PM
Quick question: I purchased a long distance add-on (400 min for $15). Do I get charged $15 every billing cycle? Or I will only be charged whenever I use up the 400 mins?
11-04-2017 02:30 PM
Thanks so much for your clarification!
11-04-2017 01:33 PM
You will get charged $15 when you buy the add-on. Its a one time charge.
11-04-2017 01:31 PM
@doomgeneration you will only be billed the once. Addons carry over until you have fully used them up.
