Long Distance Call to U.S.
03-14-2023 02:19 PM
03-22-2023 07:01 AM
Thanks, got the add-on.
03-14-2023 04:45 PM
@PM280750 wrote:How do I make a single long distance call to the U.S.?
As others have already mentioned here, the base 30-day plan only includes canada-wide calling, and no calling to USA. If you didn't by chance receive any free holiday add-ons that include that, the only option fro Public Mobile is to purchase a "1000 U.S. Long Distance Minutes" for $15, which might be a bit overkill if you only need to make 1 call. The upside is the add-on will never expire as long as your account remains active until you do eventually use up the minutes. (Even if that takes years!)
For a single call, I echo @dust2dust 's recommendation to check out the TextNow app - it gives you a secondary Canadian phone number which you can use to call any USA & Canada phone number for free over WiFi or mobile data.
03-14-2023 03:04 PM
If you and your party have the Whatsapp, you can make free calls and texting over wifi.
Same if you have an iPhone, you can make FaceTime calls.
03-14-2023 02:55 PM
Install any voip app like TextNow that also does talk and call for as long as you like as often as you like.
Calling is the same as calling across Canada - 1 -area code -prefix -last 4 digits.
Voip apps need the internet whether by wifi or cell data.
03-14-2023 02:20 PM - edited 03-14-2023 02:23 PM
you need to ensure that your account has the applicable US long distance add-on.
Then you simply call the number by dialling 1 followed by the full ten digits, including the area code.
EDIT: if you do not have a US long-distance add-on (which would have been offered with the seasonal bonuses offered every December for the past few years), if you only really need to make one call, it may be worth your while to borrow someone’s phone or use a smart device, such as a Google home, which you can call FREE anywhere in Canada or the US with a simple Wi-Fi connection.
