4 hours ago
changed my plan to Public Mobile yesterday from Fido. I am not able to sign in to my account. I could last night.
3 hours ago
@Georgesbabe wrote:Tried all of the above with no success. After I input the confirmation code, it just goes back to the sign in page.
That is odd. Please reach out to a CS Agent to help reset things for you.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
3 hours ago
3 hours ago - last edited 3 hours ago
I would try again but also click on Trusted Device before login.
You can login on the PM app as well.
4 hours ago
Hey @Georgesbabe
Sometimes the website has cache issues. Try going into your browser settings and clear the cache history and cookies then restart your browser and try again. That SHOULD work. You can even use the app on your phone which IMO is better than the website.
4 hours ago
If everything else fails, try "Forgot Password".
