Login issue
shahzadpandher
I purchased a subscription and a sim card from Public Mobile Amazon store. I activated the sim and selected a phone number. Everything went fine. But when I put the sim, it didn’t show up on the phone. I tried bunch of phones and same issue. Now I am unable to do a sim swap because my account is linked to the old sim card and I am unable to receive text messages for my account login. @CS_Agent
shahzadpandher
Yes I did that.
Yummy
You have to complete activation using PM app as a last step. Did you do that?
Abheer
Hi @shahzadpandher
For your account log-in, there is an option of "didn't get the code" and then have it sent via email.
You can contact CS Agent using the link below if you wish to
Make sure to monitor the envelope icon on the top right since that is where you will receive the response.
hi@shahzadpandher
the phone not see your sim or it sees it but does not connect?
if it sees and not connect, message support
