Log into my account
rosypeters
I cannot log into my account. I tried to reset my password. I did joy get the code on my email address.
@rosypeters
If you have been in nonpay/suspended status for over 90 days, or ported your Public Mobile number to another provider, then you lost your Public Mobile account, phone number, and access to self serve/My Account.
benfatto
@rosypeters  Open a ticket, click on https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question in SIMon. Follow / invent the prompts until you reach the Contact Us button, click on it and a Submit Ticket button should appear. To confirm that your ticket has been submitted, check the SEND box in your private messages; click on the small envelope next to your avatar at the top right of your screen.
If you have problems submitting a ticket, you can also send a private message to the CSAs. Click: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Alexandf
@rosypeters
reboot phone and open incognito mode,clear cache,cookie, try it.
will13am
@rosypeters , can you try again using incognito mode in your browser.  If that is unsuccessful, please use the chatbot link at the bottom of the webpage to initiate a support ticket.
