02-08-2026
03:41 PM
02-08-2026
05:02 PM
computergeek541
My partners phone was dropped and broke.
We are now trying to access her account to switch phones and it is saying we have the wrong email and it's not the wrong email
02-08-2026 04:54 PM
@Karlwall2 wrote:I tried and doesn't work
If forget email or reset password is not working, then you will need to contact customer service agent. Send a private message as described in first post. It will take several hours to up to one day for response. The response times seems longer than usual.
02-08-2026 04:29 PM
02-08-2026 04:17 PM
If you are sure email is right, try reset password
But try the reset and login using browser with incognito mode
02-08-2026 04:10 PM
It is saying wrong email, but it is not
02-08-2026 04:04 PM
@Karlwall2 You can try forgot email option or forgot password option see if that helps if same ask support to help
Can use the orange Chat icon or
