06-12-2024
11:28 AM
06-12-2024
02:46 PM
computergeek541
I am trying to complete my activation. I downloaded the app and started it, but when I click the Log In button, it highlights briefly but doesn't do anything else. I tried restarting the phone, deleting the app and reinstalling it, and clearing the data and cache - same result. I'm using a Samsung Galaxy A32 5G phone using Android 13 with 12 GB of free space. Any suggestions before I give up?
06-20-2024 08:48 AM
For those having the same problem, I was able to get it resolved by disconnecting my VPN. After that, the Log In button worked.
06-12-2024 02:25 PM
Oh, and I'm not using an eSIM, I'm using a real SIM card.
06-12-2024 12:41 PM
I would have thought that I needed to run the app on the phone I'm activating. Is this not the case?
If I don't have another phone, can I run the activation process on my computer or on my tablet?
Thanks for the help!
06-12-2024 11:57 AM
if you are not trying to activate esim, can you try it on another phone?
or if you have no other phone to try, then submit a ticket with CS agent, they can help with the rest of the activation steps. Submit by direct message
