Locked sin need new pin or puk
Tony26
Help please my phone say so locked enter code.
13 REPLIES 13
cappaj
@Tony26 wrote:
Code didn't work.. Now what grrr
How many times did you try incorrect codes before you received the correct one? There's a limited number of times you can try before it locks and even the correct unlock code won't work anymore. If that's the case, I think you have to contact Sony to get them to unlock it with their special code, before you can then unlock it the rest of the way with the unlock code you got from Rogers.
You could try some of the steps on this page to see how many code attempts you have left:
https://sim-unlock.net/simlock/Sony/Xperia_Z/
Note on that page where it says:
"Sony Xperia Z has a limited amount of unlocking attempts. Usually all Sony Xperia Z have 5 tries. If your Sony Xperia Z has a blocked code counter, there are no tries left, you cannot unlock this device by code.
Important !!! Sony Xperia Z with a blocked code counter will still ask for a network unlock code.
Even if you enter the correct code it won't work with a blocked code counter.
The code counter can be reset only by an official Sony service."
I don't know what model you have and if Z is different from other Xperias, but hopefully that helps!
Tony26
Tony26
I called got the number n still won't unlock wtf lol
Tony26
I'll call n find out right now thanks u
@Tony26
You might need to call Roger's to see whether your phone is still locked with them.  They can give you an unlock code for free these days.
Tony26
Was a Roger's phone.. Switched over to public mobile.. Paided for everything.. New sim. Account n plan . Installed sim.. My phones is a Xperia . N on start up it say Sim-new work unlock pin.. N on top its says sim locked my operator
Luddite
@Tony26 Are you certain your phone is unlocked? What is make/model? Where did you get it? Was is used with another carrier?
@cappaj wrote:
@RobertQc wrote:
 @cappaj wrote:
If 1234 or 0000 don't work, sometimes this kind of message can be referring to a different kind of code.
What kind of phone is it, and what is the exact message you're getting?
I thought the same thing at first, like maybe his actual phone local password but his subject line "locked sim need new pin or puk" so I didn't go any further but cant hurt to ask
Well and on Samsung at least, "PUK" can have a meaning you wouldn't expect - I described my experience with specific Samsung messages here:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/PUK-code-not-working/m-p/278460/highl...
Thats good info thanks, I will quote your post in the future 🙂
cappaj
cappaj
RobertQc
Try 1234 and 0000
If it does not work do as @popping says above
To get PUK code, reach out via private message to our support teams. Click this to send them a message
PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
 The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
  • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
  • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
 Caution! If the PUK is entered incorrectly up to ten times in a row, the SIM card becomes unusable.
 To get PUK code, reach out via private message to our support teams. More info here
popping
Send a private message to moderator to get the PUK code.
Click the following link to send a private message to Community Moderators to ask for help.
Please include your PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
Don't know your pin?--provide any 3 of the following:
- Complete mailing address,
- Email address,
- Alternate phone number,
- Date of birth,
- Last top up date & amount
Community Moderators are available from:
Monday to Friday from 9am (EDT) to 9pm (EDT)
Saturday and Sunday from 9am (EDT) to 7:30pm (EDT)
