06-24-2022 04:35 PM
I am locked out on my account And need to make a payment asap, I do not have access to the email I created the account with to reset the password. I’ve had this number for 3 years now and I can’t lost it.
My Account
Payment
06-26-2022 04:44 AM
When time really is of the essence knowing where you can purchase and load a voucher via 611 or by calling 1 855 4PUBLIC and entering your 10 digit phone number can be the difference between the life and death of your account. This post should help for future reference...
06-24-2022 05:04 PM
The 611 idea mentioned would need your 4 digit account pin to use a registered credit card. If you buy a voucher in stores or online then that does not need the pin. You can also do instant top-up in a few stores. Then you can take your time to fix your account access.
06-24-2022 04:54 PM
06-24-2022 04:53 PM
@Krista95 You can dial *611 and pay with a voucher or a cc if you have one on file in your account
06-24-2022 04:49 PM - edited 06-24-2022 04:54 PM
@Krista95 That’s good to hear then follow the advice given above good luck 👍
06-24-2022 04:49 PM
How long does it usually take them to reply? It’s kind of urgent.
06-24-2022 04:43 PM
It has not
06-24-2022 04:39 PM
@Krista95 Hello if your account has been suspended more then 90 days your account is closed permanently
06-24-2022 04:37 PM - edited 06-24-2022 04:53 PM
@Krista95 Hi if you can’t get into your account you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
